joweliedja
Thread starter- Joined
- Dec 22, 2003
- 3
I have a 1995 Evinrude Ocean Pro 175 HP. Cylinder # 3 (middle on RHS) is running hot. The spark plug (NGK Original and new)is a different colour to all after turning the engine off under load doing dyno testing on trailer at ramp. The head is OK and the top of the piston looks like it is getting hot. We changed the mixture so it would not run so lean, though it still looks like it is. Float level in the carby is OK. There are no air leaks in the gaskets with carby and manifold. The engine also misses at high revs under load. Tried new power pack, optical sensor, stator plate. <br />Cyl # 3 is the first carby to receive fuel. Is it possible that it is sucking air from the fuel tank making that cyclinder run lean and hot? Any other ideas are sincerely appreciated.<br />Thanks<br />John
