1995 150 ocean runner hose question
Rockn'reel
Hey new to the site... Had a question about my outboard. I have been doing a lot of maintenance (carbs, impeller, etc) and I ran across a loose hose laying in the front of my lower cowling. I do not want to fire this thing up until I descover where it goes in case it causes damage. The existing point of attachment is on a "rail" directly aft of the fuel rail. There are two of these rails (one on each side) and both are aft of the fuel rails. This is the port side hose that is not attached. I tried to follow the starboard side hose and find out where it attaches to the engine. I found the fitting, but I did not find any secondary nipple or fitting for the other hose. The starboard side attaches right next to the shifter linkage and steering linkage are located. Anyone have any ideas or maybe a photo they could post showing the attachment point? I cannot find my manual and not really wanting to buy another. Of course as soon as I do my manual will show up and problem solved right?
Thanks, and I will see if I can attach my photos.
dingbat
If it's like my 200 Ocean pro, that hose just gets stuck in a "hose size" hole on the lower portion of the breather cover.
Rockn'reel
Can you post a photo by chance? My photos are too big for this site and I am not savvy enough to compress them. If too much hassle don't worry about it.
What is it for? Just very worrisome when you find a loose hose just lying around in there...
bob johnson
its really no big deal...it vents into the airbox so the motor sucks the vented gas back into the combustion process...at least that how I think it reads....
bob
Rockn'reel
Thanks for the info. Just an unusual design as to why the other side is tied in to the motor itself yet the port side runs back into the air box...
Strange
