1995 150 intruder heads
bonitoman
What color and type of silicone rtv do you use on the heads? Thanks
Solittle
Re: 1995 150 intruder heads
Others will jump in & add to this but I have read many times that silicone (of any type) is a no no for OB.
rodbolt
bonitom,an<br /> I use the high temp red. but only if the motor is a 60 degree and uses orings on the head. make sure not to use to much or it will clog the cooling system. clean all surfaces with some alchohol or acetone.make sure not to use the high temp with copper. remember copper bad :) :) .<br /> good luck and keep posting
