Hey guys new to the forum,have a issue if anybody can help with?
Just got a older CC with 94 Yamaha C115 on it and its running hot and shutting down,I did check thermostats,and sensors checked fine. I did redo the WHOLE water pump/impeller assembly ( had a stronger tell tale flow).
After starting takes about 10-15 min. to get hot (going by gauge) also I did replace the poppet valve with the newer mushroom style. Removed the TS covers and after a min. or so water does flow from the holes. Also the weird thing is the alarm doesn't go off but it does work as I have checked that as well,and if I remove the temp sensors from the head while running the gauge still reads hot (doesn't move) and the alarm doesn't go off?? Iam no marine mech but Iam stumped,any ideas?? thanks
