1994 Volvo 7.4 GL Stutters and Backfires at Mid RPM's
jmsmieja
Hey everyone,
I just went through the Holley 4150 750cfm on my VP 7.4GL, and put new 2.5 power valves in it. I also found that the jets were backwards from what I had read they should be (from the link below. I have 80378-1). I moved the 56 jet to the front and the 73 to the rear.
My problem is, now I seem to be running lean at the mid-range rpm's as I come off of idle and push to higher RPM's (~1000 to 2800). The engine stutters, the rpm's sway up and down by 500-1000 rpm, and I can hear it backfiring/puff through the carb. Does anyone have any ideas what I can do to fix this? This issue did not exist before I put the new power valves in and switched the jets around. Is it possible that the chart, in the link below, is not what I should be following? I've been told to try a bigger jet in the front (i.e. 65) and possible a 4.5 or 5.5 power valve. The boat did run really rich before, which is why I went through the carb in the first place. Now it seems too lean.
http://www.v8volvo.se/mekartips/tabeller/holley-specifications.html
Thanks for your help!
Jameson
Re: 1994 Volvo 7.4 GL Stutters and Backfires at Mid RPM's
Hey everyone,
Jameson
Ayuh,.... Welcome Aboard,... Goin' on that sentence, I'd guess ya gotta be jetted somewhere 'tween where ya started, 'n where ya are now,....
Maclin
I have seen that list before and thought it was accurate. The carb I have is on there, 80309, and when I took it apart the jets, even that the secondaries had staggered jets, and power valve matched those specs. It was virgin before I rebuilt it the first time.
Power valves with that low of a number will stay closed at much lower vacuum levels, that could be a factor. Also the 56's do seem too lean to me, but I am not going to 2nd guess that spec sheet.
Makes me wonder who changed the jets around and why in the first place!
The RPM fluctuation can be a power valve tuning issue, or actual vacuum leak. Maybe try a 4.5 pv in the front?
Maclin
JMS,
I remembered a little more about the list, the one I found a long time ago also showed what spring was in the vacuum actuator for the vacuum secondary models. I will try to find that list and see if it shows different jet numbers than this one.
jmsmieja
Thanks Maclin and Bond-o. I called Holley tech support and the guy I talked to said he thought 56's were too low as well, and that the carb at spec wasn't matched well to my engine and application. He suggested 68's, which I installed this morning and it runs like a top. I also bought a 6.5 power valve to put in the front, but wanted to try one thing at a time. I'm not sure if I'll put it in now or not.
Thanks again everyone.
Jameson
