Fishjustin87
Thread starter- Joined
- Aug 7, 2018
- 113
I have a 94 115 bibbleback that I converted to a conventional diaphragm fuel pump. I bypassed the VRO. Through this forum I was told to se a 1983 140 fuel pump. Works great and runs strong. It shutters a little in gear at low RPM but seems to idle and run great at WOT. What is normal fuel consumption for a motor like this. I seem to be burning about 6 gallons an hour between Wot and putting around pulling pots. Is this normal or do I need to lean out the carbs a bit? If so what would be recommended? Both carbs have 2 screws on the face of them. Cant really use the manual for this as I converted away from the Vro. Any input would be much appreciated. Thanks
