I have a 94 tigershark. 640cc jetski. I'm trying to replace the starter gear assembly. But the flywheel is in the way to clearly has to be removed. My only prob is there is aprox a 6inch gap between the flywheel and the gas tank so it's a really tight spot to work. I'm new to this so I tried removing the gas tank then found out through research that I would have to remove the engine to get the tank out any way. So does anyone know a way to get the fly wheel off with only 6 inches of room. Can't find a puller to fit!
