I have the above boat. On the throttle, control, it's a center console. On the control, on the left, is the up down trim switch. On the right, is the lever, handle, which is attached to the left side of the control with a screw down the middle of it. There is a plastic piece that is on the left side that the screw screws in to to hold the handle in place. Problem is the little rubber piece which the screw screws in to broke off and now the handle on the right is loose. I don't want to have to replace the entire control, just the piece on the left so that I can screw the screw in to hold the handle. I've looked and have been unable to find anything, so any assistance someone can provide would be greatly appreciated. My only other option is tape and I really don't want to do that.
Found a schematic similar to the control I have, the piece i'm talking about is #2
Thanks again...
MLM
Thanks again...
MLM
