1994 or 5 GLS 195 Floor Foam Saturation issue.
blyons50
Hi,
This looks like the place. I have a GLS 195 Sea Nymph. It is a walk thru windshield 19' boat built in 1994 or 5 is my guess. Anyhow, I think the foam under my aluminum flooring sheet (it is not plywood) is water logged and is causing my transom to be low in the water. The transom drains are almost even with the water line. I could live with it but if I ever opt for a larger outboard engine, I'd be in not a good spot. Has anyone had any experience addressing this. I am thinking the foam is saturated and I need to remove and replace with ????... Anyhow I am wide open to the subject and look forward to any correspondence.
Regards,
​Bob Lyons
coolbri70
if the foam is soaked, the floor has to come up so you can replace the foam. you can use pour in foam or the foam sheeting they sell at the building supply store
