jtsaltwaterboating
Thread starter- Joined
- Oct 30, 2009
- 29
1994 Mercury 90hp two-stroke
All last year my motor could not pass 3500 rpm. Every time I try to WOT pass 3500 rpm it would just stall.
Before I took my boat out this spring I changed the following:
- Spark plugs and wires
- Change gear lube
- New fuel water separator
- Fuel filter
When I changed my old spark plug wires I noticed one of the wire were burnt. I thought maybe that would be the cause of my problem last year. But found out it wasn?t and now I have a bigger problem. I can?t even cruise at 3500 rpm like I would be able to last year. Now, I can get up to around 4500 rpm run for a minute or two then slowly die down. Then all I can do is cruise at around 1500 rpm.
Any help would be appreciated.
- Change gear lube
- Fuel filter
