1994 mercury 70hp force problem
Txboating
started perfect today, made it out to the lake and when i increase the speed it runs for about 300 yards with no problems and then bogs down to a crawling speed. it will do the same thing over and over. New to boating but would really like some advise.
jerryjerry05
Re: 1994 mercury 70hp force problem
Sounds like the tank vent is closed or clogged?
Built in tank?
6gal carry on?
Check the vents?
Txboating
thanks for the reply, after i posted my issue i decided to inspect all the fuel lines and found a line from the filter to the pump was a little weak possibly collapsing, so replaced all the lines. ill post if that fixed the problem when i get back to the lake.
