1994 Mercury 40hp Temperature Sensor Location
tomflkeys
I have a 1994 Mercury 40hp 4cylinder 2 cycle Pro Series and con not locate either the thermostat or the temperature sensor.
Any help would be appreciated.
grbeasley
Did You ever find out anything about your question? I have similar questions about mine.
Texasmark
Temp sensing wires would be tan or tan with a blue stripe and go from the engine back to the control box to ground one side of the alarm module. The tstat would be under a bulge (cover) on the rear of the block water jacket plate usually held on with a couple of screws , upper left on higher hp engines, or on the top rear of the block....just looks like something that doesn't belong.
