1994 merc 175 stalls wont restart
dwm0121
1994 merc 175 starts easily, runs smooth for a while, then stalls and won't restart. doesnt sputter, just shuts off. compression checked last summer after alarm went off a couple times ( shut off, restarted and alarm didn't go off again) all good. 20 gals new fuel/seafoam/quicksilver after leaving a few gallons of untreated in all winter. Have run long enough on ears that new fuel should be in the engine. replaced impeller this winter. The fuel ball doesn't seem to stay hard, not empty, but not hard. I know this could be a number of things, where is the best place to start?
jerryjerry05
Re: 1994 merc 175 stalls wont restart
First step of diagnosis.Do a compression/spark test.
The soft squeezie??The squeezie could be bad,or the fuel pump is shot.
Check for water in the fuel(again)
Or a hose is sucking air.Ethanol is affecting older hoses and rubber.
After checking the ball,pump,and replacing all older hoses,clean the carbs.
Install a filter between the carbs and the pump.
dwm0121
I checked the fire last night, all plugs firing. Fired for a second with a little starting fluid. Pulled a fuel line just past the fuel filter, produced a stream when cranked but can't tell if it was enough. There are a lot of part between the fuel filter and the injectors, any suggestions what it could be?
Thank you! Dave
mikeybz
I had a problem that was kinda like your . I changed the fuel ball and havent had the problem since.
Faztbullet
When it shuts off will it restart or do you have to wait a few minutes???
CharlieB
What motor, carbed, or injected?
If injected, you will need a fuel pressure gauge you can screw onto the valve on the fuel rail. The fuel pump should run for a couple of seconds when the key is first turned on, raising fuel pressure, as the motor is being cranked, the pump should come on again to keep the pressure steady.
dwm0121
Won't restart at all. I will get a pressure guage and check pressure tomorrow. What should the pressure be? I see faztbullit is from Tenn, I have been going to Watts Bar for 30 years. Love it.
No fuel pressure, I didn't notice before but can't hear the fuel pump come on. Pulled pump, will have it checked to make sure it isn't a loose/cut wire somewhere. Don't see a fuse, anyone know if there is one?
