1994 mastercraft porstar 190 chevy efi
greenale
i just started boating wih the kids i want to know when i change the oil in my boat the 94 do i need it to be in water to warm the motor up or can i just heat it for 3 min om the trailer at home i just leaning to work on boats :eek:
stockcar
Re: 1994 mastercraft porstar 190 chevy efi
You can run it sittng on the trailer BUT you need to have a water (garden ) hose putting water in the cooling system while it is running . I have the same boat , on the left side , cooling hose runs by the alternator , I remove the hose clamp at the medal filter ( ? ) turn the hose up and put the water hose down into the system . You need to run the engine until it reaches normal running temp .
