1994 Mariner 90hp Starting Problems- need help!
LonnieJ
Ok the motor will crank but not fire now, when i first got it out i replaced the plugs and flushed the fuel system, etc.... I have tested the kill switch and its not the problem, the motor would turn over without firing for a while and after unplugging the switches it fired up and ran, it would crank again and again, I let it set over night and now its back to doing the same thing again, cranking but not firing, any ideas??? I dont think it is the stator or the ignition box but im not sure,,
