Re: 1994 Johnson Fast Strike 150
I don't know if the vro pump went out only was told that the problem was the vro. NO warnings went of. A friend who I had let drive told me he was getting more rpm's than I had been able to get,I told him he should not be and then heard a tick and shut down immediately. Waited about 10 minutes and restarted motor. Motor had slight vibration. I took it home, checked compression, had one cylinder with 40 and one 90 on same bank,pulled head and the cylinder with 40 was scored up bad. Really don't know what happened but have to replace powerhead. All mechanics around my area say they can replace the entire motor for what it would cost to rebuild. Like I said I have found the 175 powerhead,think I will replace the 150 with it since it will fit. Don't need any more speed the 150 is fast enough for me.
