1994 Johnson 60hp impeller replacement
Infanta1
Hi, need information how to replace the water pump impeller. Any body know where I can get an expoded view of the enjin. Model no: J60ELERS JOHNSON 60 hp. Thanks
Cricket Too
Re: 1994 Johnson 60hp impeller replacement
Infanta1.....Welcome, check the search option above, punch in what you need and you will find past posts on what you need, they should help you. Good Luck.
