1994 JOHNSON 40HP WARNING HORN
suttonc
My warning horn on my 1994 40hp Johnson comes on and stays on while running and in the auxilary position, even when the motor is not on. Any ideas? I feel that it is not that major because it comes on before the engine even starts.
suttonc
Re: 1994 JOHNSON 40HP WARNING HORN
There are three positions on my ignition. 1-Off, 2-where the chirp usually comes on for a second, 3-the area that starts the motor. Could the sensor be bad?
DIRTPOORE96
HI SUTTONC,<br />I HAD THE EXACT SAME PROBLEM WITH MY 175HP RUDY A COUPLE OF WEEKS AGO. HORN WAS GOING OFF AS SOON AS I TURNED THE KEY. FIND THE HORN BUZZER UNDER THE DASH & CLEAN THE STAB ENDS WITH SAND PAPER. PULL YOUR CABLES OFF THE BATTERY, CLEAN & SAND PAPER THE TERMINAL ENDS. RE-INSTALL THE TERMINALS & MAKE SURE THEY ARE TIGHT. YOU ARE HAVING A GROUND PROBLEM, OR YOUR HORN COULD BE BAD. IF THIS DOES NOT FIX THE PROBLEM, REPLACE THE HORN.
