1994 johnson 25 2 stroke idles rough
Wazzup4u2c
starts up fine, shop just installed an idle stop bracket because it didnt have one and would die out, but when the throttle is all the way down, it will start to rev up and make a misfire kinda sound with a violent shutter and drop back to lower rpm and do it again, and again, whats going on?
Wazzup4u2c
Re: 1994 johnson 25 2 stroke idles rough
Bump, does this sound like a carb idle adjustment?
steelespike
sounds like a lean sneeze not enough fuel may need a carb rebuild .
