1994 Johnson 175 hp ocean runner
night pirate
Hello attempting to do a water pump in my motor, have a petty good idea what to do, however was wondering what the torque specs are for bolting lower unit back on how many ft lbs/in lbs etc should the bolts be? Also any input on what to do while apart is appreciated. Special little tricks of the trade etc.
Thanks Frank
Chris1956
Honorary Supreme Mariner
For my '98 150HP Ocean runner gearcase retaining bolts, they are:
3/8 bolts 26-28 Ft/Lb
7/16 bolts 45-50 Ft/LB
trim Tab screw 35-40 Ft/LB
night pirate
Hello ad thanks for the info, very helpful. You says trim Tab screw 35-40 ft lbs? Is that the tab set for steering the fin on lower uni housing your referring to? Ok didnt look guess that is a larger bolt?
Thanks again
Chris1956
Gee, if I remember correctly, the bolt in the center of the trim tab is pretty thin, likely too thin for a 35-40 Ft/LB torque.
I would just make them tight and not sweat the exact torque value. Use some permatex #3 sealer on them.
night pirate
Hello and thanks again, so what is trim tab bolt your are talking about? Yes either permatex or loctite blue not to strong but in salt water nothing is to strong lol! Thanks again for your input and help. I never used specs before just did by feel been so many yrs have passed since I have done and 63 yrs ya begin to doubt yourself lol 😆 I guess being over cautious? Not shore but your name u have says 1956 that’s your birth yr that’s mine, are we the same age?
thanks Frank
Chris1956
Frank, at our age, I am not usually able to break bolts thicker than 3/8". It is sorta like an age-related torque wrench.
Those 1/4 inch bolts better watch our though...
night pirate
Lol yes agree so we’re the same age, yes things are a lot harder to do now. I had several problems with this thing this yr and expense adding up. Deciding what to do sell the way it is or fix put in water and for sale sign on it he it until sold. Maintenance and expense becoming to much. I will be genial on those 1/4 bolts. Thanks
