1994 Johnson 120v4 tach?
mike stallings
i bought a procraft 1660v and the tach doesn't work. does anyone have a wiring diagram for this motor so i can try to get my tach to work? thanks
HighTrim
Re: 1994 Johnson 120v4 tach?
Here is a diagram for the tach.
You may also want to refer to you manual to test the regulator, or Joe Reeves advice from the FAQ here on iboats.
Chris1956
Mike, Does that motor have the water cooled voltage regulator mounted behind the flywheel on top of the cylinders? If so, the grey wire is the source of your tack signal. make sure that the regulator and the tach get +12VDC on the purple wire when the ignition key is in the run position. Make sure there is continuityfrom the tach to the grey wire on the Voltage regulator. make sure the Tach has ground as well.
