botticellij
Thread starter- Joined
- Jul 25, 2016
- 1
First I have already replaced the following.....stator, trigger, regulator, power pack, spark plugs, rebuilt carbs, timing adjusted. Compression 105, 100,100,95. Ok the problem. Been having idle issues with the motor. Runs then drops below 700rpms then dies. No biggie before the motor dies just put in in gear and go. Low throttle to WOT runs great. Took it out on Sunday ran awesome all day. Heading back to the boat ramp, motor starts to run really bad. Only does 4500 WOT and running 10 miles an hour. Got to the pier with the motor in the water. Took it out of gear and throttled up and the motor once again is running great, however under a load in gear the motor still is at 4500 rpms at 10mph........seems to be sputtering and bogging.
I took off the fuel water separator filter and poured it into a clear bottle but gas looks good. Also when I was on the water I replaced the fuel pump with a new one, but the problem still continued.
Any ideas what is causing this issue.......I keep thinking it's a fuel issue or fuel restriction. Deciding to ditch the whole fuel water separator filter system. The motor serial is J120TXARC.
Thanks [h=1][/h]
Thanks [h=1][/h]
