So I have a 1994 115 Johnson. The issue I am having is that sometimes it takes forever to start it. In fact, the first time after buying it it had this issue.
To get it to start when it won't start I end up having to disconnect the fuel line and push the key in repeatedly (choking it). After about 1-2 minutes of constant crank, it will finally sputter to life and then run fine. I took it to two different shops. One reset all the linkage and replaced a part that was missing there and the other re did the carbs.
I also adjusted the throttle to rev slightly higher as well. This problem does not happen all the time. Sometimes I can turn it off and it will start right back up regardless of how long it was sitting. Other times I turn it off and immediately try to crank it and it won't start.
Another issue it does is it sometimes does not immediately increase rpm when throttling up. i will hit full throttle and it can't get up off the water. Then you can literally hear the engine rpm increase and the boat will surge out of the water.
I am at my wits end with this motor. I describe it to the mechanics and they seem to have never come across this type of issue before. My only thought is there is some sort of issue with fuel delivery into the actual motor. Getting the carbs rebuilt didn't resolve it, getting the the spark plugs replaced didn't resolve it. adjusting the throttle cable to run higher rpm didn't resolve it.
I also do not think it is related to how warmed up the motor is. There is no correlation to how long it sits not started compared to whether or not it will not start. I have gone fishing and go to start the motor and it will
