1994 Johnson 112 compression and fuel delivery question
dreese2005
Hi all and thanks for the input. here is the next problem. I am down to the crank case, removed all bolts. It is still stuck at the bottom... even after removing the nuts from the studs underneath. I am attaching a photo... are these really bolts coming from the back side?
rothfm
Ensign
I dont see any pics attached.
You have a series of bolts around the case flange edge, at bottom left there is 1 up a bit higher
Then you have the 6 large bolts inside behind the intake
Two small bolts at the top crankcase head bearing that go into the case, have to be removed
Then 4 of the same at the lower ccase head bearing housing
Then it should tap up and off.
The OEM books have great step-by-step with pics!
dreese2005
Thanks, i couldn't get the pics to load. I pulled the power head completely off and found the five underneath that had to come out then the crankcase popped right off... new rings in and now going back together.
dazk14
Ensign
I'm a little late, but 90 is poor compression. The major wear area for 2 strokes are piston to cylinder wall. The bearings are all over designed.
For not much more than the cost of factory rings, you can buy aftermarket cast pistons including rings, wrist pins that will tighten up the bores as best as possible.
120 psi is a minimum target point since you have it torn down. The ring lands wear on those and the upper ring gets too much side clearance and exit the piston on those crossflows motors.
