1994 J50LERE will not stay running
Josh Huddle
Starts up and runs great but dies after about five minutes. The only way to keep it running is to squeeze the primer bulb. When I do this bubbles come up the filter. I have replace the fuel lines, new filters. I have made sure that the vents on the tank is working. I believe that it is the fuel pump, but want some advice before I spend $400.00 for a new one. Do I have to buy a new one, or is there a rebuild kit I can buy?
Honorary Supreme Mariner
The pump is driven by a positive and then a slight negative pressure pulse.----These pulses come from the crankcase.----------If there are internal problems in the engine your pump may not work properly.--------A simple cylinder compression test should be done on that motor.------------There is a $100 pump option that mounts on the side of the top cylinder.
-----What should the compression be ?---------I do not anwer that question as there are too many different guages and techniques.-------------Big thing for you in this case is that both cylinders read the same or nearly so !--------------The VRO pump is easy to take apart for inspection and is built so it only goes together one way.--------Sort of " dummy proof " it is.
Josh Huddle
Compression was 121 on the top cylinder and 120 on the bottom cylinder. I took the fuel pump apart and both diaphrams looked good. Put it all back together and the same thing happened. I do noticed that the primer bulb does not ever get hard when priming before starting. So I have a leak somewhere just do not no where. Any suggestions?
If you have a cheap plastic tank then inspect pick-up tube inside the tank.
bonz_d
Also may want to look at the orings inside the ends of the fuel line connectors.
Josh Huddle
OK the tank is good, replaced the o rings on the inlet and outlet of the fuel pump. The primer bulb will get hard now, but still getting the same resault. I do not see an leaks anywhere.
Bosunsmate
So primer bulb is now firm with engine off but you have to prime it to keep the engine running after five minutes?
Hows the tank vent?
