1994 force 90hp trim & tilt
galla
i bought the motor with the trim & tilt disconnected ive put it back on but arnt sure now wich pipes goto the cylinder and which ones to the shock(or the pin that pushes out) plse can anybody help explain which is which if u look at the unit from the front where the filler screw sits and also to bleed the system. thanks
trollhole
Re: 1994 force 90hp trim & tilt
Hey I don't know if this will help or not. I cannot remember if a 94 and a 96 are similar. But I have a 96 force 90 I'll take a few photos this weekend and send them to you if you would like?
galla
yes please trullhole im sure it will help me lot i will appreciate it a lot. what else can you tell me about your motor any problems??<br />you can mail me at ludekef@hillside.co.za
happyday
It's mid-July now, if still looking let me know by email at kd9199@aol.com<br /><br />I copied pages from the manual and might be able to scan and send them as PDF files.<br /><br />Let me know.<br /><br />By the way, this board is awesome! Almost bought a new starter but then did the obvious thanks to this board! Saved $200+!
