1994 force 120 waterpump / impeller help needed
junior
I need instructions for changing an impeller in a 1994 force 120 outboard
Model # H120412PX
I did it a long time ago but forgot the process and steps.
Its been sitting for 5 years and the carbs were run dry when I parked it.
is there anything I should look for when I go to crank it? I know I have to drain all the
old gas out but should I put in new gas then drain all of it out also.
Thanks junior
Juniorharvell@earthlink.net
Anyone willing to discuss this I can give you a call. Anytime after 6:00 pm eastern time
diaric
Re: 1994 force 120 waterpump / impeller help needed
this won't be exactly the same as yours, but this will give you the basics
http://www.brokeboats.com/newpump.html
on changing the gas. if you see lots of crud and sediment or rust, then do a flush. fuel stabilizer helps here, will keep your gas good for about a year
Kajun37
best thing to do is by a clymer's manual off ebay for your motor..has step by step instructions
