1994 Evinrude 30hp impeller change
bmaynard
When changing the impeller (normal maintenance) do I just need to replace the impeller or do I need to install a water pump repair kit. If I need a kit, what is the replacement part, Also, do I need to use any sealers, etc. Any other advice ?
theworm
Re: 1994 Evinrude 30hp impeller change
Hay B<br />I have a 40 Evinrude and when ever I change the impeller I find it always best to spend the extra few bucks, do it right and go for the kit. Year, make and model should help you with the parts at your local dealer.<br />Good Luck.
