I searched for this have not had any luck.
Hopefully someone smarter than me is lurking here...
I have a 1994 Evinrude 30HP outboard.
The starter is getting actuated but is not pushing the gear into the flywheel.
I have cleaned and tightened all battery connections.
I have even used jumper cables and run power straight from the battery to the
starter, bypassing the solenoid all together.
I can tell it has been doing this for a little while, there are a couple of teeth on the flywheel that have the bottom portion of the tooth broken off.
I assume this is from not engaging all the way.
I have checked on a new starter. Darn things aren't cheap.
First question, Does this sound like the starter like I think it does?
Next, how hard is it to replace the starter, I don't have a service manual, yet.
Thanks for lurking,
Chris
Thanks for lurking,
Chris
