LJackson61
Thread starter- Joined
- Feb 10, 2018
- 49
The boat has been sitting since 2013. After I brought it home I put in new fuel and took the carburetor off and cleaned it. It had small pieces of black trash in the bowl. The inside of the fuel lines had deteriorated. I put on new fuel lines and cleaned the spark plugs. It ran good sitting in the driveway. I took it to the lake. It did not want to idle. I was finally able to get it to go into gear without dying. It ran good at half and full throttle. I brought it back home. I found no spark on the bottom cylinder. I took the coils off and cleaned the grounds on the coil and block. Both cylinders show good spark. It is crossing the 3/8 to ½” air gap on the tester. I also checked to see that I am getting fuel. I took the cover off the fuel pump. The screen is clean and I am getting fuel when I squeeze the bulb. I am getting fuel the the primer valve when cranking the motor. Now it does not idle or run well. Do you know what the problem might be? BTW, On the driveway the other day and at the lake, there was a good stream of water coming from the tell tale. It is cool today. Around 50 degrees. I guess the thermostat did not open while it was running on the driveway. Please look at the videos I put on youtube.
https://youtu.be/ouYOeXaiKbM (At idle)
https://youtu.be/-lBpMSyC6Nc (Above idle)
