seagull369
Thread starter- Joined
- Aug 15, 2002
- 39
Im getting no spark out of my 1994 3 cyl force outboard. I fear it might be the **** switch box again. I already had the box replaced a couple of years ago (along w/ stator) due to a no spark situation. The name on the replacement box wasnt Force (or Mercury, since the motor is made by them) but rather a company called CDI Electronics.<br /><br />What kills me is that the boat ran fine until I brought it to the welder, who welded my busted skeg welded back on (lower unit wasnt seperated). I talked to the welder about my suspicion and he said it wasnt possible since current was only traveling between the short distance between the anode/ cathode which were both located on the lower skeg area. I myself am not so sure.<br /><br />Regardless of that, I have a boat that won't start now. I've heard that the switchbox cant really be checked w/out special meters which would set me back more than if I were to take it to a shop. My manual tells me I can take ohmic values for various colored wires, which might be indicate a problem. It also, of course, suggests I check all ground connections. Someone recommended that I disconnect the black/yellow kill wire and see if it sparks then, to see if the kill switch in the ignition is the cause (there is no lanyard switch on the boat). <br /><br />Any suggestions on how else i might test the switchbox to see if its working? Any other components I might want to check as well? I was planning on checking the alternator & rectifier. Anybody have any opinions on the welding scenario, and or the reliability of CDI electronics switchboxes vs OEM? Any input would be greatly appreciated. Ken
