1994 90HP Evinrude Won't Idle
Gethookedfishn
In August of 2015 I made a 17mile run to a popular Perch fishing area. On the way down the lake the Motor ran fine like always. After ready to leave our 1st fishing spot the Motor didn't want to start. We could smell gas so we waited a few minutes and then it started but had to keep the RPM's up to keep it running and put it in gear. At the next 2 fishing spots it was the same thing, but did not smell any gas. We ran the 17miles back to home Port and Motor purred like a kitten like always. When we got back to the Marina we had to wait for a Boat to get out at the Ramp. The Motor conked out in idle. We paddled into the dock and a few days later I replaced the Plugs and Fuel Filter. After hooking it up with the Rabbit ears for water it fired up but with the same problem of not idling but runs with the RPM's up.
Please advise if this could be a Coil Problem. The Motor is a 1994 90HP Evinrude E90TLERC
ondarvr
Could it be....yes, but from your description of the symptoms...no. A failing coil normally works well at low RPMs and causes problems at high RPMs until it fails completely. More likely a dirty carb, but you need to check the compression and spark before doing more work.
boobie
Do a compression test on it and a spark test. Spark should jump a 7/16" open air gap on a tester.
