1994 70hp Force Anode Replacement
bskiba
I recently purchased a Starcraft with a 1994 70hp force outboard. I have since realized that the sacraficial anode which mounts to the lower unit above the prop is missing. I have purchased a new zinc anode, but the attaching screw is also missing. Do I need a zinc screw as well, or can I use a standard steel screw?
Thank you in advance for your advice.
roscoe
Re: 1994 70hp Force Anode Replacement
Welcome to iboats.
Stainless will work well.
