1994 70hp evinrude water impeller
Phrogger
I have a 1994 evinrude 70hp evinrude. I am trying to change the impeller but can't figure out how to disconnect the shift rod. It was given to me by my grandfather so I don't want to try the things I have found until I know exactly how to do it. Please help
Michawilden
The shift rod probably disconnects in the cowling. If you follow the linkage you will end up at the shift rod. There should be a bolt, under your carbs/ inlet. If you disconnect that bolt and all the visible bolts at the lower unit you can drop it. I don't think you can remove the cowling so you will propably have to remove the starter in order to reach the shift rod linkage bolt. I am not totally sure since it is a couple of years ago that I had the similar engine.
Honorary Supreme Mariner
No bolt to take out on that one !!!------Look on the starboard side for a hitch pin.---Remove that pin and push the shift shaft to port side and rotate it.----Shift rod should now be released.
