1994 70 HP Johnson...fuel issues???
JakeT721
I recently bought a pontoon with a 1984 70 HP johnson that has been converted to premix. The boat had been sitting for a couple years so I drained the old fuel, put on new spark plugs, and rebuilt carbs. Put the boat in the water and it ran OK but would not go over 3000 rpms. Then as I headed back to the ramp at about 1200 rpms for 5 mins, the motor died. I was able to start it once more and run for a few minutes then it died and wouldn't start again. Any ideas?
Start with a compression test.------Then check for spark on all 3 leads.--------Good spark is spark that will jump a gap of 7/16" or more.--------Did you check / replace impeller ?---------Tried running with a different tank and hose ?
JakeT721
I did a compression test and got 127 on top 135 on and 150 on bottom... the plugs on the cylinders with 127 and 135 looked like they had been igniting fuel, but the bottom plug with 150 psi almost looked clean. Spark on all 3 was good. I have not checked the impeller yet and have not tried running with different tank and hose.
At this point I suggest you remove the cylinder head to inspect pistons and cylinders for # 1 and 2 on your motor.
