1994 70 hp evinrude
Jason1974lab
My motor is charging at 13.1 volt when running average speed how do I test rectifier and Stator thanks
oldboat1
Battery might be fully charged. In a regulated system, the charge rate sounds about right. Peak charge would be 14.1, probably at close to WOT.
Is the motor new to you -- any operating issues?
Vic.S
At only 13.1 volts it will not be charging the battery, at least not at any significant rate.unless the battery is in a very low state of charge or nearly unserviceable.
See the CDI trouble shooting guide, pages 7&8, for advice regarding testing the stator and rectifier:
http://www.cdielectronics.com/wp-content/uploads/2013/02/CDI Troubleshooting Guide - 2012.pdf
My guess would be a defective rectifier, assuming the battery is good, but they are too expensive to buy based on a guess without proper diagnostic testing.
