I have just aquired a 1994 40HP evinrude outboard, elec. start, remote cont., tilt/trim. it starts fine. Idles rough at 1000rpm, and smooths out a little at higher revs in neutral. Will rev over 6000 rpm in neutral and still climbing if I don't control it. In Fwd gear it runs rough at low revs, 1000 to 2000rpm, smooths out a little between 2000 and 3000 rpms. It seems to run smooth with sufficient power in reverse. The main problem is, when I try to excellerate above 3000rpm, in fwd gear up to full trottle, it increases rpm a little, ( to 3100 - 3200rpm), then labors and slows down to 3000rpm. It seems to be working very hard to maintain 3000rpm at full throttle but will continue to run. I have cleaned/replaced inline fuel filters, new plugs properly gapped. That's the extent of my attempts without good advice. What can you suggest?
