1994 30hp evinrude bucking
derek4343
sometimes the motor runs strong and other times while under load it starts bucking and jerking and even when its not under load. as if its not getting fuel. i replaced all fuel with fresh. plugs look new and dry. steady water stream..whats next?
Could be running lean and needs low speed jet opened up.-------Could be that throttle is opening too soon.-------Check the adjustment on the thin rod that goes to the back of the engine.--------Should be ~ 1/4" gap there at slowest idle position.
boobie
An ignition miss will cause this. Put a timing light on it, turn it around, look into it and see if you have any black spots. That would be the miss.
