1994 3.0L Stalls when throttle is advanced slowly
jayhamm34
I have a 1994 Bayliner Capri with a 3.0l. I was having trouble Friday night getting and keeping the engine running. I adjusted the idle so that now it starts and idles great (No tach, not sure what rpms are, that's another issue). It shifts in to forward/reverse smoothly so I am sure the shift interupter is working fine. When I advance the throttle slowly it dies. I can get it to keep running if I "gas" it really fast, but can't be doing that on the water for safety. It does this in "throttle only" as well. Is there another adjustment I can make or could it be a timing issue. Please help if you can. Thanks
Re: 1994 3.0L Stalls when throttle is advanced slowly
Ayuh,... That only works, comin' Out of gear, In the water....
It sounds like the Carb might need Rebuildin'....
hvluve
Need to adjust air. Not getting enough air in carb. I have the same problem before.
