1994 2stroke 225 hp mercury ob
chawk
when cranking engine i get soft spark on one side spark plugs and no spark on other side once when engine tried to start (a short 1-2 second run) the side with no spark hit hard with spark for that 1-2 secs any ideas
j_martin
Re: 1994 2stroke 225 hp mercury ob
Chief suspects are mercury tilt switch and kill circuit wiring. Disconnect the kill wires from both switchboxes and measure the resistance to ground. Should be very low with the ignition switch off, and infinity with the switch on. Trace out any fault.
hope it helps
John
