Boomyal
Thread starter- Joined
- Aug 16, 2003
- 12,072
The old '94 'burb doesn't get much use these days. It basically just sits outside and grows a botanical garden. This summer is proving to be good boating weather so I got it fired up and have been driving it around a bit. I even had to go get a set of used tires from the local Ruskie Tire shop because my 27k, 14 year old tires were rotting off of it and leaking air.
Everything has worked well except for today. I turned on the A/C. No cold. Examination showed that the clutch was not engaging so I assumed it was way low on refrigerant. I'll check that out later.
I pulled into the market and shut the engine off. All of a sudden it sounded like I had a woodpecker in the passenger well. Checking it out, it seems that one of the doors in the heater box was rapidly opening and closing. After a short while, it quit. I drove it home and pulled into the driveway and shut it off. The noise started over again. It did that for a short period, then quit. It did not seem to matter what position I had the HVAC controls in.
With the key off there could not be any electrical activity so I assume that it was possibly vacuum causing the doors to open and close.
Any ideas where I might look?
