1994 225 Vindicator
dnovitt
I have recently purchased a 1994 Gambler with a 225 Vindicator, which has had a new powerhead in 2003. After months of refubishment on the boat I put it in the water for shake down. Started and ran ok at idle speeds, however when I attemted to open it up it would not go beyond 1800 RPMS. New gas, tank previosly drained, new batteries, compression checks read 105 in all cyliders plus or minus. Where do I start?
tashasdaddy
Re: 1994 225 Vindicator
After months------- carbs probably varnished up, high speed jets clogged.
dnovitt
I think you idea is sound but I can shift into neutral and can rev it up to 6000 RPMS. It seems that when I put in gear it will only get up to 1800 RPMS.
tashasdaddy
no load in neutral, it is a 6 cyclinder, and can rev that high on 2 cylinders.
ezeke
You may be running on three cylinders due to a mis-aligned shift assist switch; try temporarily disconnecting the black wire from the switch.
jonesg
Get a spark gap tester, set the gap to 7/16th inch , pull all the plugs, ground them all except one.
Plug the gap tester into the first one you test, clip to ground and have someone crank the engine over, you should get a strong blue spark. Find the plugs that are not sparking.
You can use a remote starter switch, I just use a wire with a clip on one end and jump the starter solenoid when working alone.
I think you'll find a couple of dead holes, remove the coils and look for cracks in the potting epoxy or cracks (very small cracks).
You can also mark the dead coils and try swapping them with good ones, see if the problem follws the coil, if the problem stays in the same cylinder after swapping them out then test the powerpack.
Is the 94 225 an optical ignition?
Be carefull revving it up with no load, the dead cylinders might not be getting lube.
If the spark checks out ok on all cylinders , you might try pushing the ignition key in when shifting into gear to give it a shot of fuel, in which case rebuild the carbs with kits.
dnovitt
Thanks for all your help. Followed your thoughts and finally located my problem. Hot foot cable connection not allowing wot.
Dave
