1994 115hp water tube installation
Tomle91184
I just bought a 94 evinrude 115hp with the lower unit off and I got a box of miscellaneous parts and hardware. The water tube was removed and never put back in. How do I install the water tube? Does the flared end go to the block or the water pump? Do I have to remove the power head to install it? The rubber gromit, does it go to the flared end of the tube?
interalian
Flared end at top, goes in from the top with the powerhead off.
Do yourself a favour and take a compression test before investing more time/money in parts/labour.
Tomle91184
Well since I got to go through the headache of pulling the power head probably would be best to do a compression test.... Thanks for the input
interalian
Do you know much about this motor? Have you seen it run or know that/when it did?
Tomle91184
I don't know anything about it... I'm basicly going to either restore it or repower the boat... But a new problem has poked its head out... When I went to do a compression test the first cylinder I tried everything went smooth but the other 3 the adapter for the tester screwed in past the threads without bottoming out... So now I'm on standby waiting on parts
