1994 115 Turbojet
broke out a thousand
Engine will not idle and when it does run it sounds like it misses (sound sounds like rocks are being thrown around in the motor when it does miss). I have replaced all coils, spark plugs, spark plug wires, stator, timer base, head gaskets, exhaust gaskets, thermostats, cleaned out carbs, has good compression and now I am stuck and do not know what could possibly be wrong.
Honorary Supreme Mariner
What about the gearbox ?----What are the actual compression numbers ?
Recently replaced the gaskets and put the motor back into the boat. Did not check compression for it this time around will get to it this weekend or the next, and when it idles it fluctuates, it will idle then it will rev high without even touching anything, keep in mind this is when it does want to idle, I haven't been able to keep it idling, it usually shuts off after a few seconds.
