1994 115 trim
Faztbullet
Re: 1994 115 trim
Hard for one to leak up!!!:D I usually find debris in check valves in tilt/trim cylinder or cylinder scored. Have only found 1 with bad manual tilt valve.
luckytempo93
Re: 1994 115 trim
i can sit on the lower unit and it will drop really fast and i weigh 200lbs. it will solwly go down with its own weight. i had it all apart and cleaned the valve and replace all the fluids.
Re: 1994 115 trim
It sounds like you need to replace the piston seal.
luckytempo93
Re: 1994 115 trim
wont it leak up too if i have a jack under the engine putting pressure up?
