1994 115 Johnson Spark Plug Wire Question
williambad
She has not been running right lately, and took the cowling of and found out that a plug wire had pulled out the end of the boot. Do I need to get a new plug wire, or can I just slide the wire back in the boot and go?
Thanks,
Bill
jddmac21
Re: 1994 115 Johnson Spark Plug Wire Question
Same thing happened on my 96 and the local marine shop said to replace the wire. I built two just in case and it cost like $10 and did not take long.
emdsapmgr
Your plugwires are sold as a replacement kit at your local Bombardier dealer. 582365. About $12 each. I'd probably go with the factory ones, as they have the large twisted coil wire inside. Or you can buy some bulk plug wire 772584 from the same dealer-make up your own wired by using your old boots and connectors.
