1993 Yamaha 250 trxx engine wiring
K+C Rebuild
Can somone assit me, I've mounting a 250 on a pod and the wiring is almost completed. I have 2 problems, one being a 4 pole female plug that I don't know where is goes to. It is beside the main control harness on the starboard side of the engine. The colors are black,black w/ red stripe,Blue, and yellow.
The other being where does the remote oil tank level wire back to. Is there a seperate jumper up to the gauges? I have an extention but no plugs match.
jespchee
Re: 1993 Yamaha 250 trxx engine wiring
you still need answer or did you figure it out? I have a 1992 sitting at friends house, can check it you still need to know.
