1993 Yamaha 200 Tilt / Trim Electrical
tjb127
Problem started with motor intermittently going up on its' own with no buttons being pressed. Now the motor is stuck up because the down buttons will not work on the throttle or the motor. Any suggestions would be greatly appreciated.
99yam40
Re: 1993 Yamaha 200 Tilt / Trim Electrical
sounds like you have a button or wire short problem. Try disconnecting the wires from the buttons at the relay and test relay and wiring from there to see which has the problem
