1993 VRO alarm on 105 JET
Yentna
I'm new here in Alaska, in crisis mode as I'm suppose to leave on a moose hunt in the morning. Bought extremely nice 17 ft Almar light with a 93 105 Johnson FACTORY JET. The boat has 310 hours on it. The motor literally looks like new under the cowling. Last time it ran was June 2016 in the dealers tank...previous owner told them to check it out/service it. They adj the carbs, new plugs, fluids...said it looked and ran GREAT. I picked it up this May...due to wife's home improvement projects I haven't had time to even start it until tonight. Last week I removed the kicker lube oil system and cleaned up the lube oil hoses...they were then empty...I took it to the lake and like a dummy squeezed the gasoline prime build first, and then disconnected the oil line at the pump and primed oil oil was at the top go the hose...installed it on the pump. Started it, and got the fast oil alarm...plenty of blue smoke so I figured it was OK at idle. Alarm continued...I got out the operating manual which said prime oil before fuel...if not you had to remove the oil line from the engine while running, pump 8 oz into a jar, squeeze the bulb until the oil was at top of hose, and reconnect. Well, the alarm continues. The dealer did note on the paperwork that the VRO tank level float switch was disconnected, to it must be air in the pump ?? This this ran great last year so I don't think it's broken...my moose hunt takes me 50 miles into the wilderness so I'd like the warm fuzzies that it is working 8 hours from now. How do I reset the alarm? Would it be better to unplug the oil pump, plug the oil line, and premix 150 gallons? Any risk to damaging what I think is a perfectly good oil pump??? The only guy that can look at it tomorrow charges 195/hour for expedited service...it's that or wait 2-3 weeks. Thanks
ondarvr
Pre mix what you have in the tank, and I'm assuming your 17' boat doesn't have a 150 gallon tank, so you don't need to mix all of it at one time.
​Fill the oil tank and run the pre mix, measure how much oil is used from the tank at some point during the day and see if it works out to 50:1 or a bit less with amount of gas used, now at least you know if the pump is working correctly. At that time you can stop pre mixing if you want.
Yentna
thanks ondarvr...how do I kill the alarm noise? Also whats the knob under the ignition key do? Mike
Yentna
while I've put over 1200 hours on my previous inboard jet boats, this outboard stuff is very diff to me. I feel like a dummy as when I put the lower cowl back on I plugged in the oil tank brown & black wires turning on the problem the previous owner disabled. I now turn the key to the on position and get a quick chirp vs. the nasty steady alarm.
Live & Learn. The positive is my moose tag won't go to waste! Thanks again.
