1993 pontoon boat
texasabil
I have a truck i'm selling this guy called and wanted to know if i wanted to trade for a 1993 18 ft sun-dance. with a 1985 merk 90 on it i cant find any info on a 1993 sun-dance are they good ones.he sent me some pics its nice i have not owned a pontoon boat and need things to check!!! I will be checking the deck but is there more to check thanks for all the help!!! :D
lncoop
Re: 1993 pontoon boat
Probably a Sundancer. They are still in business. Don't know a whole lot about them, but given its age I suspect it will have foam filled toons. If so, I would pass. Also, that sounds like too much motor on an eighteen footer, so I'd ask the seller pointed questions about the motor. Obviously it's a repower, but you need to know the story. Also, 18' is pretty small. It may be plenty for you, but if you have a couple of kids I doubt it. Regarding what to check in general though:
1. Shake the front of the barge then quickly put your head close to the toons to listen for sloshing, but note that if there are leaks you wouldn't necessarily hear the water if the toons are foam filled.
2. Check the motor pod for cracks or other signs of trouble.
3. Check compression on the motor of course.
4. Turn the steering wheel as though you were driving. An unusual amount of slop of stiffness could be a sign of trouble.
5. Turn on all switches, stereo, etc.
6. Poke your head under the helm and look at all the wiring. A rat's nest of wires is an indication the boat has been subjected to bubba mods.
7. Run your hand along the upholstery. It should feel thick and soft. If it feels dry and brittle it won't be long until new vinyl time.
9. Take a good look underneath the boat. Look for bent or beat up pieces, missing bolts, etc.
10. If possible, jack up the trailer and spin the tires while listening closely for bearing noise.
11. Check the trailer lights.
12. Check the trailer frame for rust, cracks, etc. and the bunks for rot or general degradation.
13. Water test extensively.
There's a really good thread from some time last year about what to look for if you want to read more. Good luck.
texasabil
Thanks for the help!!! man ill check and see if the pontoons are foam filled i do think he said they where so going to look at it this weekend and probably pass!!! i have been looking at 18 ft and the biggest hp is like a 50 hp i have seen so far!!!
Jeep Man
There should be a plate indicating max. horsepower. Check it out. If the pontoons are aluminium and round, they are likely air filled. Any other style are probably foam filled. Depending on the layout, some 18s are as roomy as a 20'. Most buyers prefer 20'-24'. At the end of the day, condition is everything.
lncoop
Actually, there was a surprising number of foam filled round toons made in the nineties. Not sure why, but you know how it goes. There's nothing inherently wrong with having the foam, but consensus is it doesn't provide any real advantages, and if (I mean when:rolleyes:) you develop leaks if you don't address them pretty soon you'll end up with waterlogged foam, and I don't think I have to tell you what that means. I had an 18' Godfrey Sweetwater for one season. Full length was actually 19' 2". She was maxed out with a 50 horse Yamaha and was a sweet little barge. I loved that boat. However, my wife and daughter quickly determined that it was too small, and as much as I hated to admit it, they were right. I sold her and bought the Suntracker in my sig, which is not nearly as well built as the Godfrey was, but still an enjoyable rig for us.
